10v UR Quattro parts wanted
Hi. I'm new to this forum but wondered if anyone could help me.
My engine tends to idle really fast - between 2 - 3k revs particularly when hot. I figure I need to replace the idle stabilisation valve but if anyone has any suggestions please let me know. Also the small connecting hose which appears to take water to the turbo from a banjo fitting on a thermostat housing on the head and connects to the metal small bore pipe around behind the timing belt is looking tired and I think I should replace it in good time. Can anyone tell me where to get it please. Thanks |
I got that hose / pipe from the dealer.
The ISV is unlikely to be the fault if the rpm is at 2k. The ISV can only control the idle across a small range |
High Idle
Thanks for that. I'll try Rupert for the pipe.
What are the other possibilities for the high but variable idle speed? |
Morning everyone!
Can anyone out there help me find a replacement dashboard for my S2. The LCD has failed and the odometer stopped working completely when I zeroed it. Thanks for looking. |
Best place is ebay or s2forum.
Audicoupeparts has broken a couple S2's in the last month so he may also be able to assist :tup: |
I have no idea how much S2 instrument cluster costs, but presuming at least twice as much as ordinary one, replacing one must be choice of someone who has lots of spare money - for the rest way to go is by obtaining any B3/B4 VDO cluster with necessary parts in working condition and swapping them - especially if that unknown LCD belongs to clock, not trip computer.
| All times are GMT. The time now is 03:45 PM. |
