-   -   injector rubbers (http://www.classic-audi.co.uk/forum/showthread.php?t=2413)
Micky 29-10-08 06:27 PM
injector rubbers
how do i change injector rubber grommets? i have taken out the injector. do i need to disconect the fuel line or will it slide up from the bottom of injector?:confused:
randall977 29-10-08 07:22 PM
If it's the later K-Jet type with a chrome end it should stretch over it and sit in the groove once pushed up the injector. I used a bit of oil to help it to sit in the plastic cup - most went in easily but one was an absolute pig???
Micky 29-10-08 07:26 PM
thanks i will try that .all the rubbers are hard as nails:(
randall977 29-10-08 07:40 PM
Can you buy new ones? They are pretty tough - takes some pushing to get them on!
Micky 29-10-08 07:43 PM
yes gsf sell them and the dealer sells them about 50 to 70p each they are same as the golf
spaarky 13-11-08 05:18 AM
but if you're desperate, the rubber rocker stud o-rings in an aircooled vdub gasket set work just as well i.e. any good quality o-ring of the right size should do the job
