-   -   CQ or Wr Panels (http://www.classic-audi.co.uk/forum/showthread.php?t=20855)
tommyboy 06-01-12 11:00 PM
CQ or Wr Panels
Hi guys
After a few panels out of either a CQ or a WR if there's a rotten shell worse than mine out there somewhere.
Rear boot panel: Replacement for this:
http://i881.photobucket.com/albums/a.../Photo0070.jpg
Sill area/Door corner shut drivers and passengers:
http://i881.photobucket.com/albums/a...C00037edit.jpg
Front Panel:
http://i881.photobucket.com/albums/a...to0012_001.jpg
Boot floor area:
http://i881.photobucket.com/albums/a.../Photo0069.jpg
If anyone is able to help id greatly appreciate it. Id even travel locally ish to help with removal of panels.
Accident damaged or cheap bare shell considerd if these area's are in good condition.
If no luck ill look into having to fabricate the following part's
Cheerz
Tonks4x4 06-01-12 11:55 PM
If you are intent on saving this car my advice would be to strip it to an absolute bare shell. Only costs your time. Box everything up and label everything.
Send the bare shell for sand blasting inside and out everywhere, I send my shells to a local company that charge £350 - £400 it comes back spotlessly clean and painted in etch primer.
When it comes back repair all of the holes and rotten sections. The blasting will highlight any parts that need repair that may not have been seen before and would creep up and bite you in the a$$.
If you intend to use it for Motorsport this is the time to also stitch weld every seam.
Re seam seal all of the underside. Treat it to lashings of POR15 or other underbody protective paint.
Have all of your running gear blasted and coated, or blasted and painted with POR15. Blast and coat a full set of running gear is approx £250
Decide if you want to make coil overs or just to refurb and refresh standard shocks and springs
Re fit the running gear and then at least you have a rolling prepared shell for what ever route you finally decide to go.
Don't forget if you are going down the A2 body route some of the steelwork highlighted will be cut away to fit the wings
tommyboy 07-01-12 12:16 AM
Hey mate
it is a absolute bare shell at the moment (bar pedal box). Everything that i need for the 20 valve conversion is all stored away. The pics up there I've used for reference before it was stripped down.
There's a few plans in motion already (part paid for and awaiting pick up)
AAN engine and 6 speed box. Full Running gear to match
Already got the s2 Hubs and front subframe
Pick up a bare shell of Acidburn that can be used for replacement panels along with a few other parts
Only thing holding me up is awaiting room to fit the car again. That should change in a week or 2
Thanks for the advice mate. Ill look into were local will do the shot-blasting and etch primer for me.
3 cars.And i cant even put one of them in some were dry at the moment.Want to know why. . .
F*****N donkey's ma mum rescued have taken up residence!!
Tonks4x4 07-01-12 12:39 AM
Lol, use your head then, buy a car transport trailer and adapt the front end to accept horse driving gear.
Stick the donkeys on the front and get some use out of them :)
tommyboy 07-01-12 01:12 AM
Lol probable go faster than any of the 3 cars lol
Will hopefully keep you's updated with progress.
Spent last 2 hours looking into Van hire,shotblasting,and sending out pm's to people that if i pay them in tim could pick up part's
the engine and box,6 speed linkage and wiring loom,
rear diff,struts,shafts,prop wishbones
3/4 of a coupe shell
2 front A2 Wings going cheap on ebay locally
4 and 2 pot calipers for me impreza
That would be a worthwhile trip going as far south as Acidburn's
swb quattro 07-01-12 05:19 PM
hi there tommy i thought my shell was bad but now that i have seen yours i feel so much better:lol:
tommyboy 07-01-12 05:34 PM
Lol Thanks :L Nothing a bit of ingenuity and hard work and learning cant sort lol
swb quattro 07-01-12 08:34 PM
yeah we will get there in the end have you sourced a front panel and rear panel yet
tommyboy 07-01-12 11:49 PM
I havent sourced a front panel yet. Will hopefully be using a rear panel of a GT coupe. Any details and pics of your project
Acidburn 08-01-12 12:20 AM
give me a week or two ;)
