-   Transmission (http://www.classic-audi.co.uk/forum/forumdisplay.php?f=30)
-   -   01E into typ85 (http://www.classic-audi.co.uk/forum/showthread.php?t=2072)
jogi730 14-09-08 03:50 PM
01E into typ85
I have finally bitten the bullet and bought myself an 01E six speed gearbox.
I know it's not a diect replacement.
Does anyone have the rundown of all the parts I need to acquire to complete this swap?
Many thanks
Chris
s2rob 14-09-08 04:03 PM
try the search,its been covered a couple of times......if your not a spanner man its not going to be easy!!i have done a couple of conversions now....check out s2forum
jogi730 14-09-08 04:10 PM
Tried the search, but can't find anything.
Ideally do not want to go the 5 stud conversion
Cheers
Chris
s2rob 14-09-08 04:21 PM
a 6speed linkage will be required,together with the gear lever(which will need modifying)unless you chop the raised section of the s2 tunnel and weld it in,the x member is different as the 6 speed mounting is in the wrong place(nearside only..offside should be same)ball joint sizes are different if you use 6 speed subframe.......you will be better off getting gearbox mounts made up to fit the origanal x member(or subframe)....clutch centre plate is different....only easy thing is it bolts to any 5 pot engine...good luck with the project...more info on quattro forum or s2 forum....i have been informed there will be an artcle about this conversion in audi driver mag
jogi730 14-09-08 04:29 PM
Rob,
Thanks for the info. I may well go down the S2/ Audi coupe subframe route to help with roadholding issues (ie standars AARB's). I have changed my wishbones to cast ones from the standard pressed jobbies, so I am running S2 balljoints already.
WHat about drive shafts and the prop shaft?
ANy more innfo or links to this conversion would be most helpful and I will bviously keep my eye open for the article.
Cheers
Chris
s2rob 14-09-08 04:34 PM
propshaft and front shafts should be direct fit....will try for some links..
