Audi 80 Springs
does anyone know if the springs on an audi 80 1.9 tdi
saloon are the same as on the avant version? :confused: |
I don't have ETKA to hand, but I imagine they'd be the same fit, but a different spring rating.
Always fit the right rated springs for the vehicle. Mixing up springs can cause serious handling issues and imbalance. Hoyle. |
Yep, Ratings are different for rear only and different again if quattro...:tup:
thanks for that info, folks - can anyone recommend
where i can buy a set of four lowering springs for the old audi 80 tdi saloon version? muchos thanks, craig:) |
http://www.motorsportworld.co.uk/det...40&PID=1081025
Try here? Depends on how low you want to go. Eibach pro kits are good for subtle 30-40mm drops whist retaining ride comfort. Hoyle. |
Craig, I was recommended by VAG80 on here to look at the Supersport Sprint kits (one of Germany's biggest selling brands), they do a 40/40, 60/40 or 60/60 mm drop. Dave (VAG80) has a 60/40 it in his and it sits nice.
Look good value at circa £200 as well. http://http://www.venommotorsport.co...=Audi&model=80 |
| All times are GMT. The time now is 07:06 AM. |
