So, you've been out......
........ for a drive, your car has discs and pads all round - should there be any heat on the rear wheels (alloys) when you stop?
a/ Nil b/ Slight Heat c/ roasting Discuss...:hmmm: |
depends on how much/hard you have used your brakes
you will allways get heat soak |
yes coz if you havent you aint trying hard enough :hand:
c. Roasting - if the brakes ain't hot you ain't driving it hard enough :devil:
Nil, assuming normal driving.(and your brakes are in correct working order, wheel bearings haven't collapsed and you've remembered to release the hand-brake !)
J. |
Depends,if you leave your handbrake on?:lol:
In my defence, I'd been on nights. |
I did it,when I 1st started driving.:lol:
Wasn't fully on,one click.They didn't half,heat up.:lol: |
If they are roasting could well be siezing up,common problem with rear discs due to under use.
| All times are GMT. The time now is 11:25 PM. |
