Audi coupe quattro 20v
This is a really tidy standard 7a coupe which i purchased off a forum member a few months back, it has just had a new engine fitted which has covered 60000 miles, whilst the engine was out all gaskets where replaced and the engine has been vapour blasted and painted.
the car itself is very tidy with only a few points that let it down which i have listed below. if you are looking for a car to spend very little money on then this is the one all the hard works done so it just needs a bit of a tidy up to be a mint example. The bad points: The roof is covered in hairline scratches it will need paint to bring it back as the scratches are to deep to mop out. The windscreen has moisture ingress around the seals. Plastic trim missing from the towing eye. Crack in the rear bumper. Good points: Huge service history main dealer and specialist. s2 exhaust sounds great! 2x ecus one standard and one chipped tubular exhaust manifold virtually new tires and brakes any questions call 07507894023 cheers alex Pics to follow |
| All times are GMT. The time now is 11:41 PM. |
