-   -   Rattley top end.Valve clearancey sound. (http://www.classic-audi.co.uk/forum/showthread.php?t=17019)
SteveCat 08-04-11 10:52 PM
Well...the Coupe 16v has a tappety sound from the camcover for sure.
What is the set up under there? Shims and Hydraulic tappets??
Are shims easy and cheap enough to get hold of??
David Small 08-04-11 11:56 PM
Hydraulic tappets Steve, mine rattles sometimes from cold for the first mile or so
pimpdriver 09-04-11 05:56 AM
Just do an oil change then live with it.
Phil Payne 09-04-11 06:51 AM
Hydraulic. Use at least 20W oil and a Mahle OC85 filter (with anti-drainback valve).
missfire 09-04-11 10:04 AM
so i need one of them also.....not a chinese unipart white can, like the one on it..?:shake:
there you go Mr Catman, i put that filter part no. into google and this came up!
http://www.isham-research.co.uk/quat...ine/15-20.html
Phil Payne 09-04-11 10:23 AM
I hate it when that happens.
Roger Galvin 09-04-11 03:24 PM
I think the OC85 has been deleted by Mahle, I've been using the OC47 equivalent supplied via Pete at quattro Corner for some months now.
Phil Payne 09-04-11 03:43 PM
Heh. So it seems, around a year ago:
http://www.l-auto.by/cms/images/sove...ent%20list.pdf
But I'm still getting OC 85s. Someone somewhere must have had a hell of a stock.
rickytractors 09-04-11 04:23 PM
My next door neighbor drains the engine oil and fill the sump with derv and runs it for 10 mins on tick over then drains it. Said this works on tappy hydraulic tappets, never tried it my self don't no what it would do to the seals.
BIGGYIN 09-04-11 06:13 PM
Hydraulic,don't use shims.:nonod:
I have,the same problem.:(I'm going to try,a flush first.
If that doesn't work,I'll change the tappets.(After,checks.)
