-   -   84 ur quattro turbo (http://www.classic-audi.co.uk/forum/showthread.php?t=15972)
Jamie Young 01-02-11 09:53 PM
84 ur quattro turbo
Hello guys, just a quick question, the standard fuel pump on my quattro is knackered, should i replace it wih the original bosch 4414400940, or is there a modern sensible upgrade ?, cheers, Jamie
john johnson 01-02-11 09:59 PM
If your keeping it standard or it is standard then just replace it . A Bosch 044 may be a bit too lively
86audicoupe 01-02-11 10:46 PM
Get the original Bosch pump. No point buying the 044 unless you are planning to do some significant tuning. I recently replaced the fuel pump on my coupe quattro (had minor engine work done by previous owner), just fitted the standard fuel pump and drives superbly. Fuel pumps never reach their maximum rated pressure so a standard pump will be more than adequate!
Gordon WR 02-02-11 10:05 AM
Plenty of spare capacity in the original so best to follow advice given, mine was replaced with standard.
DJones 02-02-11 09:02 PM
Mine runs 450bhp with a 20v on a standard pump, though the sequential injection helps on a 20v motor.
Just replace the standard one..:tup:
john johnson 02-02-11 09:08 PM
Crumbs......450bhp at your age too:yikes:
DJones 02-02-11 11:34 PM
Sod off..... you got more grey than me......
Phil Jameson 03-02-11 12:07 AM
Get the Bosch original and sleep well.Audi knew what they were doing.Trust me.
john johnson 03-02-11 12:26 AM
That's true !
