-   -   diesel running..... (http://www.classic-audi.co.uk/forum/showthread.php?t=13547)
AAN 5pot 16-09-10 07:56 PM
diesel running.....
Obviousy you wouldnt unless you own a farm but if you had a diesel could you run it on heating oil and a bit of engine oil to lube the pump every other or 1in 4 fill ups.....??
rich.r 16-09-10 09:23 PM
a lot depends on your diesel pump
old caddy pick ups will run on clean cooking oil and dont believe all the b*llshit you hear about heating oil
i was talking to a supplier a couple of years ago about using heatin oil in my escort van and his words were "its the same as you get at the pumps " his words not mine
its the same as red diesel the colour is only a dye and i have heard if you filter it through tea it removes the dye but i havnt tried it or used it
but of course you could be prosecuted for tax eveaion using some or any of the above
h t h rich :D
AAN 5pot 16-09-10 09:29 PM
red comes up red....... engine oil comes up blue and ive been told heating oil comes up white aswell.................:ihih:
wouldnt do it all the time on the farm as the injector pump gets to dry.
hoe about R-reg bmw 525tds?? think they are mechanical rather than common rail.......??
rich.r 16-09-10 09:32 PM
whats with the red comes up red bit?
i believe you can run cooking oil in most stuff
i would have thought an old beamer would be ok on most things
thats not an instruction incase it all goes t*ts up :D
AAN 5pot 16-09-10 09:39 PM
the dye colours when you dip them...........:ihih::ihih:;)
rich.r 16-09-10 09:42 PM
oh thats what you meant
try the tea filter then :smilewinkgrin:
i do believe a lot of people that run old knackers use red and take a chance if the car is seized by h r c they only loose a couple of hundred quid and whats the odds of a car being pulled at the side of the road next to nill
AAN 5pot 16-09-10 09:45 PM
when you sack 40,000 coppers not much!!!:D
