Typ 44 suspension bushes.
The 100 avant is pootling along nicely and has taken me all over the place. Recently it completed a trip up to Elgin in Scotland towing a large trailer and in a few weeks were all going to Cornwall in it. Great! Not bad for an old banger eh?
Anyway, the handling has started to go a bit floppy and I can feel things in the suspension department moving about on braking and cornering. Sooner or later im going to need a set of bushes (probably sooner tbh) Does anyone here know of a kit thats available that coveres all the bushes in the suspension? Should I go for polybushes over the normal rubber type? How much and I looking at and how difficult is it to do? Many thanks! |
You will have to go OEM for bushes, they are not made by powerflex for your 100. Apart from the wishbone bushes at either end, but the whole arm is £25 with bushes.
Good luck in finding them!!! |
You are right, just the inner and outer wishbone bushes are available in poly, I suspect these are the ones that have gone soft though. You can also get "steering arm to rack" bushes, whatever they are!
Found a listing to some of them on ebay for you Tim.....
http://cgi.ebay.co.uk/POWERFLEX-BUSH...item3f0033d406 Steve:tup: |
| All times are GMT. The time now is 02:21 AM. |
