High level brake light wiring??
Hi all,
Anyone know how to wire in a high level brake light without it sending the auto check into a complete huff? :? (1990 90) Tia Dan |
Nice one, just the switch at the top of the break pedal i assume your on about??
:tup: |
Part 857 919 471 controls/monitors the rear lights and brake lights - there's a special version of this for the central brake light; 443 919 471B I presume this latter extends checking to the central light, but if it's enough for you that the two at the side are checked, then you need to wire into the brake circuit upstream of 857 919 471. Check for a 1.0mm red/black wire that goes live when the brake pedal is pressed. |
Thanks phil,
Aye i seen some sort of box there when i was wiring in the alarm, wondered what that was lol :o I would settle for it wired in, but would prefere to do it right if possible, anything to help blind spastics see me braking and not write this one off on me lol ;) :yikes: |
